2003 accord lx 2.4 ignition issue
Old Sep 9, 2015 | 08:37 PM
imaworkinmaniam's Avatar
Default 2003 accord lx 2.4 ignition issue
hello guys, im working on a car for a friend and it has a weird issue.
its only running on 2 cylinders.
i replaced a coil pack thinking that was the problem but its not. apparently the left 2 cylinders arent getting power to the coil packs.ive checked fuses and relays, and tomorrow i am going to check at the ECU whether there is power at the wires there.
has anyone had an issue like this before?
if there isnt power at the ecu for those cylinders, im thinking it might be his ecu.
Old Sep 10, 2015 | 05:41 AM
Turtlehead's Avatar
The cylinder numbers are 1 thru 4 with 1 being on the end of the engine where the drive belt is. Please let us know which cylinders (left for someone looking at the engine while infront of the car would be 1 and 2, while on the mechanics left would be 3 and 4.
Have you verified spark or no spark on the miss firing cylinders. What are the check engine codes?
Old Sep 10, 2015 | 09:45 PM
Which two coils are not getting power? Almost liike Turtlehead said, "left for someone looking at the engine while in front of the car would be the passenger side, while on the mechanics left would be the driver's side."
Regardless, here is a photo:
You might want to refer to this other thread for some tests: https://www.hondaaccordforum.com/for...t-start-61330/
anupm12
Apr 27, 2015 04:23 AM
shehadehd
Sep 20, 2012 05:20 PM
rampcrawler
Sep 17, 2012 02:56 PM
Cubeman
Jul 23, 2012 12:40 PM
Mrowkoob66
Nov 1, 2011 10:04 AM
