90 accord ignition issue
Old Jul 29, 2012 | 02:37 PM
rampcrawler's Avatar
Default 90 accord ignition issue
hello again to everyone! turn the key to start and dash lights all come on. turn the key to start and nothing, I can push start the car and it runs, the nipple for the clutch safety start switch broke replaced that also got a new switch didn't work. had the starter off and had it tested at auto zone test was good car has power from battery, is it possible the test was faulty
Old Jul 29, 2012 | 03:18 PM
Moved your post. Read posting rules and follow.
Have you checked the starter relay on the driver's side kick panel?
If relay is good, somehow the clutch interlock switch is not mechanically closing to enable the starter relay, or there is a cut wire in the clutch interlock circuit.
Old Jul 29, 2012 | 03:19 PM
well i just jump started the starter and car started right up cleaned all grounds and battery cable connections and still nothing from the key WTF
Old Jul 29, 2012 | 04:09 PM
Check for 12V start signal on the small wire to the starter. From your description, 12v signal must be missing, which indicates problem in keyswitch start circuit.
Old Aug 1, 2012 | 04:30 PM
Sorry forgot i was in DIY when the car wouldnt start. Update the car has 4 safety switchs, 2 under the dash and on under the hood and one on the side of the dash. hot wired the one with no ohms and the car runs better than ever thanks for the tips
Old Sep 16, 2012 | 09:07 AM
Jonathan Lanier's Avatar
Ramp crawler,
What exactly did you do to fix your problem? I'm having a similar problem.
Old Sep 17, 2012 | 02:56 PM
there are 4 nuteral switchs around the dash. the one that went bad on mine was under the dash. laying on my back looking up youll see a plastic connector attached to a switch. the plug is yellow, once i removed the plug I hot wired it, little wire conneting the 2 holes and the car started, i havent replaced it yet so if i turn the key without the cluch pushed in the car jumps. hope this helps
N4chtm4hr
Jul 28, 2014 08:30 PM
Maria Penguini
Jul 15, 2014 10:39 PM
shehadehd
Sep 20, 2012 05:20 PM
Cubeman
Jul 23, 2012 12:40 PM
Mrowkoob66
Nov 1, 2011 10:04 AM
