2003 Accord LX 4 cylinder Tranny Slippage
Old May 19, 2013 | 01:47 PM
Golddoor's Avatar
Default 2003 Accord LX 4 cylinder Tranny Slippage
2003 accord with 219,000 miles. The transmission Has been slighty slipping after stopping at a stop and then accelerating again. This happed for a few weeks. Went and had the tranny oil changed and seemed better for a while then back to the same ole thing and then gradually worsend as time goes on. Then yesterday I started the car early in the Morning and heard a whisteling sound coming from under the hood. Popped hood and noticed it was in the tranny area on the right side. Got in it and as I drove it. I got a block away and stopped at a stop sign and the car kinda lunged and then no drive gear. So I dropped it down to second and it went for about a few miles then second gear went out. Stopped the car. Turned it off then restarted and it started driving fine. For about another block. Then same thing. So I shu it off and now I'm posting for suggestions?
Old May 20, 2013 | 05:18 PM
Can you check for stored codes in the PCM?
Did you check the fluid level, don't assume as if there is a leak then it is not full anymore.
Neptun3
Jun 22, 2013 09:44 AM
dhenry
Jun 25, 2012 10:41 AM
Jmoney
Jun 8, 2009 08:43 AM
Vancefish
May 2, 2008 09:48 AM
newwct
Sep 19, 2006 10:37 PM
