2003 Accord Sedan Driver Control For Passenger Window
Old Aug 28, 2017 | 05:05 PM
OneLuckyGuy's Avatar
From: SD, MN, WI, NM and travel to other southern states in the Winter.
Question 2003 Accord Sedan Driver Control For Passenger Window
Front passenger window will power down and up from passenger control. Driver control for that window will power the window up when open but will not lower it when closed.
When the window is down or partially down and I try to raise it I hear a click and the window goes up. If I try to lower it when it is up or partially down I do not hear the click and it does not work.
The first problem I have ever had with this vehicle with 142,000 miles.
Old Aug 29, 2017 | 12:19 PM
Symptoms suggest either faulty switch in driver's control panel or broken wire somewhere (usually in door jumper).
Old Aug 29, 2017 | 01:30 PM
Thank you for the lead. Don't think I know enough electrial to tackle that unless I find someone to help. I look for some video.
bulldog1
Aug 20, 2019 10:24 AM
jrobida
May 16, 2015 08:18 PM
jza240sx
Apr 30, 2013 04:14 PM
RobJL94
Aug 14, 2012 06:56 AM
Fat Ryan
Mar 18, 2012 04:39 PM
