2003 Accord water leaking into interior
Old Sep 18, 2009 | 01:25 PM
puresoundz's Avatar
Default 2003 Accord water leaking into interior
I have a 2003 Accord EX (4-door) and have recently noticed that when it rains hard, water leaks into the interior. It is not visible, but I have found the floor in the back (behind the driver) seat is soaking wet.
I found a TSB:
"03-037 - Roof Molding Channel Leaks Water To Interior" but am not sure how to find information on how to fix this problem.
Any assistance in addressing this issue would be much appreciated!!
Old Sep 18, 2009 | 01:28 PM
Lightbulb Hi New Member...
I just moved you into the correct area to ask a question..Thanks For Posting It..but look at where your posting the questions..Dont get mad, just look where your posting those questions...
Old Sep 18, 2009 | 01:36 PM
Lightbulb Hello Again:
This subject is one of the hardest things to find out, I have a Body Shop owner who I know quite well and he tells me that the leaks are very time consuming and hard to tell where they come from..he always says that water runs where it wants to and then leaks a puddle..did you find a bad rubber molding that has maybe a little chunk of it missing?
Old Sep 18, 2009 | 01:43 PM
puresoundz's Avatar
Oh man, that is not reassuring news. This has been a very wet summer, and these leaks are starting to (get) me off.
I will look for cracked/broken/missing rubber ASAP.
Old Sep 18, 2009 | 02:20 PM
Exclamation
If you think you have found an area that may be leaking, spray some rubber seal spray in that area, then see if it still leaks..you can get a can of that sealer in most any parts store...
Old Sep 19, 2009 | 11:26 AM
hondadude's Avatar
Here is the TSB;
http://www.freewebs.com/hondadude/a03-037leak03Acc.pdf
Also check to be sure you don't have a plugged up drain tube in the sunroof.
Old Sep 19, 2009 | 11:35 AM
Lightbulb Thank You HondaDude
Originally Posted by hondadude
Here is the TSB;
Thanks Bill, that's a great link you have there..
Ang
Attached Thumbnails 2003 Accord water leaking into interior-wheel_ep-r5honda2006.jpg
Old Sep 25, 2009 | 10:24 AM
puresoundz's Avatar
Wow! Very useful! Thanks a lot!
I will try this out
larrycrilley
Jun 22, 2013 09:43 AM
Jacob305
Jun 6, 2013 12:35 PM
churritos567
Oct 14, 2010 08:36 PM
brave_mhy
Aug 23, 2006 04:35 AM
St3v3
May 14, 2006 04:05 AM
