2003 Electrical Problems
2003 Honda Accord LX has some weird electrical problems, symptoms:
- No key left in ignition chime
- door courtesy lights turn on / off with the door open / closed (lights in the door panel)
- dome light turns on with the switch in on position
- dome light turns on when the door opens only if ignition is in on position
- electric door lock does nothing when ignition is in acc or off
- electric door lock unlocks, but wont lock when ignition is in on position
- lock/unlock on key remote doesn't do anything
- same behavior on both driver and passenger side
I'd probably treat the dome light and the locks as separate issues for now.
I'd recommend troubleshooting the locks first.
Is your car a 4 or 2 door?
For the locks, do you have the same problems with a different remote? Does the key in the driver's outside door handle lock/unlock all the doors? I'm trying to eliminate possibilities.
milescwright
May 23, 2010 09:46 AM
silverstreak89
Aug 16, 2006 02:17 AM
