2003 Electrical Problems
Old May 18, 2022 | 12:01 PM
howudodat's Avatar
Default 2003 Electrical Problems
2003 Honda Accord LX has some weird electrical problems, symptoms:
  • No key left in ignition chime
  • door courtesy lights turn on / off with the door open / closed (lights in the door panel)
  • dome light turns on with the switch in on position
  • dome light turns on when the door opens only if ignition is in on position
  • electric door lock does nothing when ignition is in acc or off
  • electric door lock unlocks, but wont lock when ignition is in on position
  • lock/unlock on key remote doesn't do anything
  • same behavior on both driver and passenger side
I dont think it's the door switch because the door light turns on / off with the switch, unless the switch is multi-pole?
Old May 18, 2022 | 03:15 PM
I'd probably treat the dome light and the locks as separate issues for now.
I'd recommend troubleshooting the locks first.
Is your car a 4 or 2 door?
For the locks, do you have the same problems with a different remote? Does the key in the driver's outside door handle lock/unlock all the doors? I'm trying to eliminate possibilities.
Old May 18, 2022 | 09:24 PM
howudodat's Avatar
The car is a 4 door.
The key in the door does not unlock all the doors
Sadly I only have one key
tuscolavol
May 8, 2015 06:09 PM
twasau
May 7, 2011 09:22 AM
milescwright
May 23, 2010 09:46 AM
ramrod1460
Dec 24, 2009 06:12 PM
silverstreak89
Aug 16, 2006 02:17 AM
