2003 problems
Old Feb 17, 2018 | 07:31 PM
Refer to the photo in my previous post for Connector E. Connector E is at the end, with 31 terminal pins.
The order is A, B, C, D, and then E.
Old Feb 17, 2018 | 07:52 PM
I forgot about this other quick check.
Unplug the connector to the Throttle Position Sensor (TP Sensor), you’ll get a Check Engine Light; but, see if you can shift out of Park.
If you can shift out of Park, power from the Brake Switch is probably passing through to the PCM, and the PCM is probably sending the ground signal to the Shift Lock Solenoid.
Old Feb 18, 2018 | 05:11 PM
2003accordlx's Avatar
I did the test with the pcm plug mine is a little different than the picture but I test the port you said I have no power with brake pressed. I also tested the tps sensor the car reved a little but still couldn't get it out of park
Old Feb 18, 2018 | 05:14 PM
Once In a while it will let me take it out of park I can see and hear the solenoid working but it's not often
Old Feb 18, 2018 | 05:35 PM
1. If there is no power (+) at terminal 22 of Connector E of the PCM with the brake pedal depressed, then that indicates an open (break) in the circuit.
Just to be clear that the correct wire terminal was tested; the Wht/Blk wire is a wire with white colored insulation and a black strip running through it.
When you tested, did you use a jumper from the Red wire to the Wht/Blk wire at the brake switch connector, or did you depressed the brake pedal with the brake switch connector plugged in?
2. Before we proceed with the next test, let me know whether you used a jumper or not at the brake switch, so we can rule out other cause(s) of the previous results.
Old Feb 18, 2018 | 05:48 PM
On terminal 22 the wire was not white with black. I did use a jumper. I'm not good at this computer stuff I can't post a picture of if would you be willing to text me so I can send a picture to you
Old Feb 18, 2018 | 05:54 PM
  #17
On connector E I will look for a white wire with a black strip but it will no be in the location you gave me do you want me to do this
Old Feb 18, 2018 | 05:56 PM
  #18
I figured out the picture thing I will post one in a little bit of the plug
Old Feb 18, 2018 | 06:06 PM
  #19
I should have included the following information regarding these Honda circuit diagrams. For female side terminal connector, the terminal numbering is on the wire side; for male terminal connector side, the terminal numbering is on the terminal cavity side.
Old Feb 18, 2018 | 06:50 PM
  #20
