2004 Accord Backlight Radio Issue
Old Aug 21, 2012 | 10:05 PM
2004-Accord-Help's Avatar
Default 2004 Accord Backlight Radio Issue
I have a 2004 Accord EX and several of the backlights are not working.
The main section is the radio, buttons 1-6 as well as the AC control buttons are no longer backlit. The sunroof controls are also failing to be back lit.
Is there a certain fuse I need to check? I couldn't figure it out.
Thanks for the help.
edit: attached the image initially but forgot to resize it. here it is: http://imgur.com/8hMws
Old Aug 21, 2012 | 10:12 PM
Common problem. Faulty printed circuit board (pcb).
Old Oct 16, 2012 | 05:53 PM
bpeterson's Avatar
I have a similar issue but all of mine work except the 6 outside backlights: am/fm, cd/aux, seek/skip, tune, rdm, and rpt switches are all dark. everything else works great (knock on wood). would this also be a faulty PCB? i've been reading up on it but i'm just trying to figure out if the outside switch backlights are changeable or not. Thanks for any reply.
Old Oct 19, 2012 | 12:40 PM
bucknaz's Avatar
I have the same issue. I found a Youtube video that explains the issue and a solution. Kudos to the guy making the video for explaining it so well.
Old Oct 20, 2012 | 12:47 PM
Thanks for the info!
If I ever get around to doing this i'll make sure to post an update.
Old Nov 12, 2012 | 08:32 PM
bucknaz's Avatar
I got my interior dash tools delivered to me on Friday, I took the steroe out and soldered the wire to jump the 2.3 amp like the YouTube video and it worked great. My stereo backlight is back in business. Total time was about 45 min to remove the stereo, solder the wire and reinstall everything.
Old Nov 13, 2012 | 06:06 PM
Thank you for the follow up....
wellman
Apr 13, 2014 04:19 AM
jz99927
Apr 11, 2014 02:10 AM
treypal
Feb 8, 2012 11:56 AM
qchonda
Sep 26, 2009 10:49 PM
doctorpowder
Sep 12, 2006 11:26 PM
