2004 Accord EX Dashboard Dead, Engine starts,stuck in park
Old Dec 29, 2023 | 04:58 AM
jimc328's Avatar
Default Same problem
I am having the same problem on my 2007 Accord EX. I installed a new radio and it came with a backup cam. When I was installing the backup cam the problem started. No dash lights backup lights went out and shift interlock stopped working? Any help would be appreciated.
Old Dec 29, 2023 | 06:27 AM
Starrman's Avatar
Default Under Dash fuse box needs to be replaced
The same thing happened for us. As soon as we installed the new radio and started to install rear camera we lost the dash lights, turn signals, gear stuck in Park, power windows out, etc. THE SOLUTION is replace the entire fuse box under the dash to the left of your left ankle. We found several at the local junk yard for $30. New is not available. The reason is that this fuse box has a CPU behind it on the reverse side. Not
easy to change because of the 10 wire harness plugs. Let me know how it works out for you.
Old Dec 29, 2023 | 09:41 AM
jimc328's Avatar
Default Thank you.
Thanks, I will do that. I just didn't know where to begin after checking fuses. I will keep you posted.
Csb2000
May 1, 2022 03:46 AM
AccordRacer124
Mar 11, 2012 08:32 PM
kathy
Aug 20, 2011 09:17 PM
victorcay
Aug 17, 2008 09:54 AM
