2004 Accord Ex V6 with ACC
Old Oct 2, 2007 | 11:59 AM
Good to go
Default 2004 Accord Ex V6 with ACC
Hi guys, I have a 2004 Accord Ex V6 dual climate control and I am not getting any heat. The temperture gauge is showing normal. The blower motor is working. The upper& lower rad hoses are hot to thouch and the lower heater core intake hose ishot, the heater valve is working ok...but the top return heater hose is cold to thouch.So the hot cooling is not circulating through the heater core. Any suggestion would be appreciated.
Old Oct 2, 2007 | 02:05 PM
falkore24's Avatar
Default RE: 2004 Accord Ex V6 with ACC
[sm=headbang.gif] signature
Old Oct 2, 2007 | 02:49 PM
Good to go
Ok Wayne, I have don't everything you said. Now will you help?
Old Oct 2, 2007 | 02:55 PM
sir_nasty's Avatar
There should be a flow valve just before the heater core that opens/closes to allow the exchange, this may be hanging up, trace your lines into the heater core and look for it, make sure it's still connected etc. Is the car still under warranty by chance?
Old Oct 2, 2007 | 09:23 PM
smaglik's Avatar
ORIGINAL: falkore24
man...i understand your frustration...but give these new people a break...he had the model yr engine in his post....christ...
Old Oct 3, 2007 | 10:07 AM
falkore24's Avatar
On accords, the 2-door and 4-door models are basically different cars. I couldn't tell you how much time I've spent looking to help people and had it turn out to be the wrong model.
How do you know that the valve is working properly? If it is, it sounds like there's something in your heater core .... bad news. Have you ever used radiator sealer? That stuff can gel and cake onto the tubes and cause restrictions. Since you have a total blockage, I'd suspect the valve.
PS - Thanks for the signature.
Smag:[sm=icon_stickpoke.gif] [sm=shootshoot.gif]
Old Oct 3, 2007 | 01:33 PM
smaglik's Avatar
they might...but that's a fact of growing up in the midwest...part of the dialect, even the die hard catholics.
Old Oct 6, 2007 | 10:56 AM
Good to go
I got heat, thanks guys, I replace the valve and now it's working fine. Much appreciated
Old Nov 23, 2007 | 01:35 PM
vishnuo
Hey guys, i have a similar problme on my 2004 accord with dual climat. I get heat when teh car is driving, but when im at idle the air goes cold. When i rev the engine to around 2 - 3k rpm i start getting hot air again? Any suggestions?
Old Nov 24, 2007 | 08:02 PM
nafango2's Avatar
you will get more replies if you start your own thread, that way people will see it. Also, post it in the General Tech Help section, the DIY request section is not really for asking for help, although its not really strictly enforced.
Itstheaccord
Oct 11, 2012 08:03 AM
wheresbrando
Apr 10, 2012 11:00 AM
hondaccord04
Feb 18, 2012 07:11 AM
tcodi
Aug 12, 2006 11:33 AM
Moder
May 28, 2005 09:29 AM
