2004 Accord EXL Coupe Brakes
Old Dec 3, 2006 | 10:20 PM
Vpsophmore
Default 2004 Accord EXL Coupe Brakes
hey I'm a noob when it comes to fixin cars. Bikes I can work on, but not so much these things. anyways, I have a 2004 accord coupe ex-l 4 cylinder 5 speed and it's making this terrible squealing noise while I drive. It sounds like its coming from the brakes (similar sound when I'm stopping). First it only happened when I was braking so I thought it was just time for new pads, but now I hear it while I'm riding around not braking at all. Any ideas how much this'll cost me?
Old Dec 3, 2006 | 11:40 PM
hondadude's Avatar
Default RE: 2004 Accord EXL Coupe Brakes
Well if you let the pads wear all the way down the squealer tab will rub the rotor all the time. So if you don't change pads the squealer tab will eventially get enough vibration and break off, then the noise will go away until the steel backing pad starts dragging on the rotor.
CHECK THE BRAKE PADS ASAP
Old Dec 4, 2006 | 02:12 AM
deserthonda's Avatar
if it needs pads and you do it yourself,,,,,,,Honda pads cost about 50-55 dollars,, there is an How to in our DIY section ,,,,
like Dude said,, if you let it go any longer pad will did into rotors ..resurfacing or replacing will cost you more money. take a look ASAP..
VETKLLR
Jan 9, 2012 05:13 PM
2004exlv6
Mar 12, 2011 04:12 PM
Valkman
Aug 19, 2009 09:57 AM
starbuck1975
Jul 3, 2007 06:34 PM
mrfatride
Sep 9, 2006 05:40 PM
