2004 Accord LX Heater Problems
Old Oct 27, 2019 | 08:37 PM
mwcawood's Avatar
Default 2004 Accord LX Heater Problems
I just turned on the heater and it blows cold air on all the different controls except when i put it on vent and it blows hot air out passenger side but still cold on driver side. Any suggestions on where to start to fix issue?
Old Oct 27, 2019 | 10:41 PM
Could be an issue with your air blend doors or a possible clogged heater core.
Start with the simple test. Go to the common DIY thread in the gen tech help forum. There is a link for HVAC codes on your car. Get the codes and post any codes you get on here.
Old Oct 28, 2019 | 04:55 PM
mwcawood's Avatar
My control unit does not have the same buttons as shown in your pics. Its not a dual control nor has buttons to turn off heat and cooling system.
Old Oct 28, 2019 | 05:10 PM
mwcawood's Avatar
Also both lines of the heater core are hot. Where are the blend doors located. I did check the actuators and both work.
Old Oct 28, 2019 | 05:13 PM
I put both versions on there. Does your control unit match my second post?
Old Oct 28, 2019 | 06:49 PM
mwcawood's Avatar
Yes that is the unit I have and just did it and no lights blinked after test.
Old Oct 29, 2019 | 09:14 PM
mwcawood's Avatar
Any other suggestions on what to try or look for? I have seen some videos about reverse flushing but they only state about the whole system not blowing warm air.
Old Oct 29, 2019 | 10:32 PM
Seanjordan20's Avatar
You should have 3 actuators. Check your air mix door actuator and your blend door actuators. You're going to have to have someone help you by changing the modes and temps while you look. 2 on the right 1 on the left.
OfficerDic
Dec 7, 2014 12:26 AM
weannaun
Jan 18, 2013 05:14 PM
beagle
Sep 25, 2011 08:06 PM
Don59
Jan 6, 2011 09:26 PM
wannab
Sep 2, 2008 07:31 PM
