2004 Accord misfire
Old Apr 30, 2022 | 09:07 AM
2hondatom's Avatar
Default 2004 Accord misfire
I have 2004 Accord 4 cyl with 187K miles. Recently it began what feels like a misfire or a hesitation during acceleration and at lower highway speeds. I changed the plugs at 100K so I have done that again as well as changing the coil packs. This seems to help some but there is still some fluttering (for lack of a better description) at lower speeds. I have only driven it about 5 miles since the tune-up. Is this something that may go away after more driving as the computer adjusts to better plugs and coils? I know that may be wishful thinking but if that is not the case, does anyone have any suggestions as to what I should do next?
More info:
No check engine light ever came on
I have not changed the fuel filter
I have not done an injector cleaning
Old Apr 30, 2022 | 04:03 PM
Do you have a certain rpm range where you notice the flutter/hesitation?
Old May 1, 2022 | 12:51 PM
2hondatom's Avatar
PAhonda,
Not really, but it seems to be happening at lower speeds and rpm. I just haven't tracked that aspect of it.
Old May 1, 2022 | 02:19 PM
If it happens at a certain rpm or maybe speed, it can help give direction. The PCM should adjust quickly to a plug change.
You may want to stop by a parts store and have them scan for codes to be thorough.
Maybe try cleaning the EGR ports. See youtube video called 2003-2007 Honda Accord EGR Passage cleaning. This should cause a check engine light on your car, so it may not be the problem.
Do you have a scanner/code reader that can read live data?
Red955i
Aug 13, 2024 10:07 PM
Frank2004accord
Jun 5, 2018 01:07 PM
jelly53
Jun 8, 2011 10:21 PM
trmccone
Sep 4, 2009 07:11 AM
ttypez
Oct 7, 2007 02:12 PM
