01 accord misfire
Old Oct 6, 2007 | 01:49 PM
ttypez
Default 01 accord misfire
Hey guys, my 01 accord is running rough at idle but smooth while driving. I've got p0301 cylinder 1 misfire and a pending p1399 random misfire code on a 2001 accord with a 4cyl. In the last 48 hours the plugs, wires, cap and rotor have all been changed. Any ideas? Clean out the egr? fuel injector maybe?
Old Oct 6, 2007 | 05:04 PM
deserthonda's Avatar
Default RE: 01 accord misfire
was the issue there before you replaced plugs, wires , etc etc?? used NGK plugs ??Assuming plugs and wires are ok..
done a compression test?? chk the injector as well.. get a screwdriver and put the blade side on the injector and the handle side on your ear,,, compare all the injectors they all should sound the same ( clicking noise ) ..( engine running of course ) also a possible valve too tight ??
Old Oct 7, 2007 | 02:12 PM
sosaman's Avatar
i'd try a good fuel injector treatment. i've had good luck with gumout (in the gray bottle). as mentioned by deserthonda, was the misfire there before you changed that stuff? did you gap your sparkplugs as well? it could be that you have a clogged fuel injector (or partially clogged), so i always recommend a good fuel treatment, as well as some better gas. g/l, sos
Resatimm
Apr 28, 2016 05:56 PM
500$accord
Dec 30, 2011 10:34 PM
Adders
Apr 17, 2010 07:51 PM
hmd810
Mar 18, 2009 08:35 AM
TYTALEX
Mar 19, 2006 12:57 PM
