Remove door card on 92 accord lx
Old Oct 7, 2007 | 03:09 AM
Mr_Accord's Avatar
Default Remove door card on 92 accord lx
Hello,
Does anyone know how to remove the front driver side door card on a 92 accord lx, My window isn't rolling down properly so i need to get in behind there to grease the rollers and take a look at what is going on?
Old Oct 7, 2007 | 05:14 AM
srlance24's Avatar
Default RE: Remove door card on 92 accord lx
What specifically do you mean by not rolling down properly? Sticking, making noises, grinding? I recently had a problem with my passenger side window sticking in a few places as it went up and down. Went to autozone bought some white grease, hit the railings that the window slides up and down on and no problem since. BUT if you need to take off the door panel, you can buy a manual or just figure it out, there are relatively few screws and the clips come off easy. Just watch out for the wiring harnesses and door handle cable.
Old Oct 7, 2007 | 09:29 AM
gaugeman's Avatar
Remove 2 screws, one in the door handle and one in the opening pull lever escutchen. The escutchen then slides either forward or back (I forget). When loose disconnect it from the rod. The electric window push button assembly also pries out and must be disconnected. from the harness. There are then spring clips and plastic push in "rivets" all around the edges of the panel which pry out. When everything has been pried out the panel will lift off. Sounds worse than it is, only a 5 to 10 min. job!
Old Oct 7, 2007 | 04:20 PM
Mr_Accord's Avatar
The window will go down about a quarter of the way then is this loud skipping noise occurs and the handle will continue to turn but the window won't go down, but I can put the window back up.
Old Oct 7, 2007 | 04:54 PM
smaglik's Avatar
ORIGINAL: gaugeman
escutchen.
impressive!
Old Oct 7, 2007 | 05:07 PM
2POINTautO's Avatar
http://techauto.awardspace.com/doorproblem.html
Here is some door panel removal help, it sounds like you need a regulator.
Kelsen
DIY Answers.
Apr 7, 2020 11:46 PM
Motman Idaho
Mar 22, 2012 10:20 PM
justinit
Sep 24, 2009 04:56 PM
joshhocking
Nov 26, 2007 11:54 PM
poller
Jan 16, 2006 12:22 PM
