1988 Accord Misfire at 60+ MPH
Old Apr 17, 2010 | 01:50 PM
Adders's Avatar
Default 1988 Accord Misfire at 60+ MPH
I have a 1988 Honda Accord 2.0L 12v (Non Injection). The car seems to run smoothly up to about 45/50 mph but at around 60/65mph the car starts to misfire slightly but enough to make the car jerk uncomfortaby. I have changed the plugs, leads, dizzi cap, rota arm, oil and air filters but this has made no difference. Any help greatfully recieved.
Nick
Old Apr 17, 2010 | 07:51 PM
kris_loehr's Avatar
You could do a cylinder balance test to determine which cylinder is misfiring or if it's a global problem affecting all cylinders. You brake torque the motor to the RPM of the miss and have someone pull the spark plug wires one at a time using the all plastic pliers made to prevent shock and see which cylinders or cylinder makes the least amount of change. I would suggest have the vehicle in Reverse while holding the brake rather than drive.
raydavid93
Mar 16, 2013 09:23 AM
papaschilling
Nov 17, 2010 04:03 PM
codes
Dec 18, 2009 09:34 AM
bnavarre
Dec 3, 2008 07:42 PM
leo0909
Oct 1, 2007 11:57 PM
