Ocasional over heating
Old Apr 16, 2010 | 06:08 PM
percyg23's Avatar
Default Ocasional over heating
whats up peeps?!? hey I have a 1997 accord wagon 4cyl it will over heat every so often. I have noticed that my fans arent running on my radiator. Isnt there a relay switch for the fans? If so where is it? I have checked all my fuses they are good to go, I dont think its the thermostat because it would run hot all the time. I am thinking its on the housing where the hose comes from the radiator to the engine where the thermostat housing is, it has a green plastic connector for the wires? If you guys know I would appreciate help. Thanks
Old Apr 16, 2010 | 06:14 PM
That green switch turns on the fan(s) when the engine gets to a certain temperature. You can unplug the switch, jump the electrical connector with a piece of wire, then start the car. At least one fan should turn on. Maybe both?
You can also turn on the a/c when the car is running and both fans should turn on.
If not, then I would check for voltage at the electrical connector for each fan with the car running and a/c turned on.
FYI: the driver's side fan is called the compressor fan, and the passenger's side is called the radiator fan.
Old Apr 16, 2010 | 06:53 PM
deserthonda's Avatar
http://techauto.awardspace.com/overheating.html
let your finger do the walking in our DIY section
Old Apr 17, 2010 | 07:56 PM
kris_loehr's Avatar
The Fan will also not come on if you don't have good coolant flow over the temp sensor for the fan which could be a thermostat problem.
dcsmith
Oct 9, 2007 10:16 PM
longneck8769
Aug 13, 2006 05:12 AM
93Accord10thYear
Jun 21, 2006 05:43 PM
ibad007
Aug 7, 2005 03:11 AM
Wishitwasa355
Aug 6, 2005 07:41 AM
