2004 accord sirs codes
Old Sep 14, 2016 | 01:19 PM
Jpat1957's Avatar
Default 2004 accord sirs codes
I have airbag light on and went to orielly and came up with codes 6-1 and 9-2 . Something about system failed or low voltage. Don't have a clue, newer battery . Someone else told me its belt buckle or a weight! And help would be appreciated
Old Sep 14, 2016 | 02:37 PM
Jpat1957's Avatar
Newer battery 6 months ago.
Old Sep 17, 2016 | 07:10 AM
It would be nice to have the "subcode" but these get us close.
A 61-"X" ("x" being the subcode) points to something in the driver seat buckle. A short or open depending on the subcode.
Some have been able to "clean" the latch/buckle....some have had luck with the dealer replacing it under warranty...
A 92-"X" points to something in the pass airbag cutoff indicator.....again a short or open in the system dpending on the subcode.
If you are going to do this yourself, I suggest you get a good service manual - not a haynes/chilton thing but a service manual......and a volt meter will be needed as well.
Evlampius
Jun 4, 2008 12:24 PM
pturnbul
May 3, 2007 02:30 PM
larrysnach
Mar 11, 2006 10:48 PM
megaman
Mar 10, 2006 01:13 AM
rcm800
Feb 17, 2006 02:56 PM
