97 Honda Accord Trowing Codes!
Old Mar 9, 2006 | 12:05 AM
megaman's Avatar
Default 97 Honda Accord Trowing Codes!
I got the codes read on my 97 honda accord 2.2 non-vtec and the only code it was trowing is PO401. "Exhaust Gas Recirculation Flow Insufficient Detected". What would cause that? I also would like to know what would cause a code of PO104....just because i think the girl that read the code might be dyslexic. The PO104 code is "Mass or Volume Air Flow Circuit Intermittent" The car runs fine. The code just popped up out the blue. Any and all help is greatly appreciated! I really need help on this one as i am used to carbed vehicles! The car does have headers!
Old Mar 9, 2006 | 01:11 AM
98accrd's Avatar
Default RE: 97 Honda Accord Trowing Codes!
EGR valve is probably clogged if it's a PO401. On a Po104 either a Map sensor or an intake air temp sensor.
Old Mar 9, 2006 | 01:24 AM
AgentofDarkness's Avatar
You can also push the diapragm on the EGR valve. This should allow exhaust gas into the cylinders, and the engine should start to run like crap. If this doesn't occur, then there is a clog and the exhaust isn't reaching the cylinders. If it does occur, then the valve might not be getting the signal from the EGR solenoid or the vacuum line is broken,
Old Mar 9, 2006 | 06:03 PM
megaman's Avatar
Thansk for the input i will give it a try tonight. Has anyone else succesfully fixed this code? I have read a lot were it will comeback. Also how do i reset the computer? I had a probe that i disconnected the neg bat term and pressed brake for 3 secs. Is it similar?
Old Mar 9, 2006 | 06:13 PM
lightshow's Avatar
you have a problem that needs to be fixed...completely stop thinking about just erasing the code. if you egr isnt working right, even if the check engine light is off you wont pass emissions at all/
Old Mar 9, 2006 | 10:56 PM
megaman's Avatar
I understand that. Will the light go off once it is fixed or how will i know if what i do makes any difference because i cant tell any difference than from before the light came on.
Old Mar 10, 2006 | 01:13 AM
lightshow's Avatar
yea the egr wont make the motor run bad it will just make it not pass emmissions. on v6 hondas the ports that lead the the egr get clogged and a 200 procedure needs to be done and then the check engine wont come on for that problem ever again. with your car........it may be that the egr itself went out and needs to be replaced. i havent really heard of the egr ports clogging on your model but its possible depending on the fuel that has been used and the style of driving.
techjohnny
Feb 3, 2011 09:29 PM
PiksPal
Dec 31, 2010 10:03 AM
H1$_H0ND@_G1RL
Aug 2, 2010 08:38 PM
tonylanz
Sep 16, 2008 06:08 PM
pturnbul
May 3, 2007 02:30 PM
