rev problem
Old Mar 8, 2006 | 06:30 PM
Edinburger's Avatar
Default rev problem
hi guys
how to adjust idle
when i start my car and leave it in neutral gear car rev counter sits at below 1 and car turns off by itself car stalls
is there any easy way to increas rev/idle i want my rev to sit at 1 when car is start and in neutral gear.
any help would be much appriciated
many thanks
Old Mar 8, 2006 | 07:24 PM
mbo1985's Avatar
Default RE: rev problem
Actually, there might be a few things going on here. Your car should idle below 1000 (500-700 rpms to be exact). I'd check/clean your air filter first. If that looks good you may need new spark plugs or injectors. Does it only stall while trying to idle? Or does it want to stall other times.
The idle is controlled by the coolant temp in the manifold, so there's no screw or anything to change it (at least on my 96 accord). Good luck man!
Old Mar 8, 2006 | 09:24 PM
Edinburger's Avatar
no it doesnt stall when trying to idle and i also noticed if car is in neutral gear rev is jumping up n down fluctuating between 400 to 1000
while im driving its ok it only stalls when i stop my car for example im driving in 3rd gear and approaching traffis lights as i stop at traffic lights car stalls .
thanks
Old Mar 8, 2006 | 10:17 PM
lightshow's Avatar
well you have to tell us which year car you have.... it really depend on if its fuel injected or carb. if its carb you have a vacuum leak, and if its FI,,well then you have a problem with your idle air control valve. the latter does happen sometimes on 90-93 accords.
Old Mar 9, 2006 | 05:24 AM
Edinburger's Avatar
hi
yea sorry forgot to say its a 1991 2.2i 4WS
thanks
Old Mar 9, 2006 | 10:16 AM
mbo1985's Avatar
Your car should be FI then. Sounds like the idle air control valve too. My friend had a 91 accord that used to bounce around 400 and 1000 like yours and that was his problem.
by the way, doesn't 4WS stand for 4 wheel steering?
Old Mar 9, 2006 | 04:48 PM
Edinburger's Avatar
air control valve is this expensive part and would i be able to fit it ?? bare in mind im not a very techy guy when it comes to cars.....
and yes mate it is 4 wheel steering handling is sweet as f when it comes to cornering
Old Mar 9, 2006 | 06:12 PM
lightshow's Avatar
any junk yard will have it as well as ebay too.
Old Mar 10, 2006 | 09:51 AM
mbo1985's Avatar
haha I've always wanted to find an old 4ws accod and have it just for fun! But hey, I'm having plenty of fun with my 96 lx right now.
Yeah, ebay or a junkyard is your best bet. Replacement on a scale of 1 to 10 is probably a 1.5.
It's held on by two bolts on the back of the intake manifold (looks like a little black cylinder attached to a little metal block). Just undo those 2 bolts that hold it to the manifold and the electric connector and it's out! Try to get a new "O" ring with the new part, but if you can't get one, make sure you're careful with your old one.
chavez69
Oct 28, 2014 10:50 AM
JxATI
Feb 20, 2014 12:34 AM
pnutt7733
Nov 2, 2012 09:11 PM
shynana
Jan 4, 2012 11:57 AM
corey
Jul 2, 2008 04:34 PM
