2004 Accord - Week A/C Problem
Old Sep 11, 2015 | 09:39 AM
msa768's Avatar
Default 2004 Accord - Week A/C Problem
I have a 2004 Honda Accord with Nav. and dual climate controls. I have a problem with the air conditioning that I have not seen before. The A/C is blowing cold air but when using the temp controls with the AUTO setting engaged it is weekly blowing out of the vents. I have replaced the blower relay(last year) and had the system recharged last weekend, still not working as it should. If I lower the temp to the lowest setting it does blow with some force. If I set the controls manually to the max setting it will blow with some force. I need some help identifying the problem...Please Help!
Thanks
Old Sep 11, 2015 | 09:05 PM
cj1's Avatar
cj1
Look for a thermostat located somewhere on front of dash. You'll need a electrical diagram
To check its proper operation.
Old Sep 12, 2015 | 10:17 AM
The Climate Control System has extensive self-diagnostics capability. You will need a shop manual to guide you on how to extract codes and what they mean. Suggest purchasing a download manual from automanualsource.com for $22.
There are sunlight sensor, cabin air temp sensor, outside air temp sensor, and evap temp sensor that could be source of your problem.
JOSHENATOR
Apr 12, 2013 05:30 PM
engtaz
Jul 1, 2011 02:10 PM
jorwex
Feb 23, 2009 10:21 PM
kahnvict850
Aug 20, 2008 09:22 PM
whitelotus420
Jun 20, 2007 07:09 PM
