99 Accord radiator needs water once a week.
Old Jul 1, 2011 | 07:53 AM
engtaz's Avatar
Almost A Senior Member
Default 99 Accord radiator needs water once a week.
My wife's 99 Accord radiator needs water once a week. New radiator, radiator cap, upper hose and thermostat. We don't see any puddles on ground and it's not overheating till it get low. Suggestions?
Old Jul 1, 2011 | 09:04 AM
draser's Avatar
Look for milky stuff on the oil cap/dip stick, also steam out the tailpipe.
Old Jul 1, 2011 | 10:48 AM
engtaz's Avatar
Oil and radiator fluids are clean.
Old Jul 1, 2011 | 12:22 PM
Tek310's Avatar
most likely a water pump going bad. there is a hole that coolant will come out of on the waterpump housing when pressure gets high and the pump isnt pushing the coolant through.
when my ol'e ladies cavalier snapped her drive belt, it shot half the coolant through those seep holes from the pressure build up.
Old Jul 1, 2011 | 02:10 PM
It has to be going somewhere. Rent a radiator pressure tester from a parts store. The system should be able to hold 15 psi. If it doesn't, the you will have to try to find out where coolant is leaking.
JOSHENATOR
Apr 12, 2013 05:30 PM
Jan 30, 2010 11:01 AM
jorwex
Feb 23, 2009 10:21 PM
kahnvict850
Aug 20, 2008 09:22 PM
whitelotus420
Jun 20, 2007 07:09 PM
