2004 Headlight out problem
Old Dec 20, 2010 | 07:05 PM
schwartb's Avatar
Default 2004 Headlight out problem
Drivers side headlight went out on our 2004 Accord. Replaced with new sylvania lamp. headlight still out, but only drivers side. Are they fused separately? Any help appreciated.
Old Dec 20, 2010 | 07:36 PM
Yes, the two headlight have their own fuse.
The No. 1 fuse (10A) in the under-hood fuse box protects the left headlight low. The No. 6 (10A) protects the right headlight low.
Old Dec 21, 2010 | 07:34 AM
schwartb's Avatar
Default Thanks
thanks redbull. I tried fuse this morning they look good. even switched left to right and left still out, right still works. any other ideas?
Old Dec 21, 2010 | 11:42 AM
Time to start checking continuity in the wiring...
Old Dec 22, 2010 | 06:09 AM
schwartb's Avatar
Default Idiot Meter
Instead of using an ohm meter, I tried my idiot meter.....I was apparently trying to fix a low beam light-out situation by replacing my high beam and finding when the lights were turned on that location was still out. Once I switched to the correct location and bulb type things worked out really well. A real Homer Simpson....doooh!
schwartb's Avatar
seriously though, thanks for the help from those of you this site!
Old Dec 22, 2010 | 09:56 AM
Yeah, when you actually replace the bulb that's burned out it makes a difference
We've all done stuff like that.
Persistedx
Dec 12, 2014 12:32 AM
kouken
Jan 24, 2012 01:41 PM
Joewp
Nov 27, 2011 10:02 AM
rburtonrmx
Mar 2, 2007 08:36 PM
