2004 Honda Accord 2.4
Old Mar 10, 2014 | 11:09 AM
hondalover209's Avatar
Default 2004 Honda Accord 2.4
Hello everybody I am new to the forum, but definitely not my first Honda. I currently own a 2004 Honda Accord EX 4 cyl 2.4. I have about 108,000 miles on it and has been very well maintained all of its life. These past few months off and on I have been experiencing a rough start. The car does start but just sounds rough. Sometimes not always rarely it doesn't start and I have to try to start it a second time to start. I had a check engine light and a mechanic informed me it was my ECM. But after he cleared the check engine light which was 2 months ago, it has not come back on. I have replaced the battery with a Honda Genuine battery and also I have replaced the spark plugs, at 90,000 miles with the serpentine belt replaced as well (both done at Honda dealer). If anybody has a rough idea what it could be please help me, I would like to get to the bottom of fixing this issue. Thank you
Old Mar 10, 2014 | 01:52 PM
Any overheating history? Rough start that clears and runs OK can be a leaking head gasket.
Also possible to be a leaking fuel injector allowing fuel to drain into intake manifold and cause a slow start w/ roughness.
What code (Pnnnn) was found by mechanic? If Check Engine Light comes on again, have codes read by AZ, ORielly, etc and post the code number.
Does car run/idle smoothly after warming?
Old Mar 10, 2014 | 04:59 PM
car doesn't run rough once it is started it runs and drives great. I took it to a mechanic and now they are informing me that my starter is going out, and that it is getting weaker and eventually just die out. I just want to make sure before I replace it and spend money, just to make sure if it will be a waste or not.
Old Mar 11, 2014 | 07:21 AM
Is the starter weak, slow, or inconsistent spinning the engine (before the engine fires)?
If it's rough & sputtering for a few seconds after the engine fires up, that's not the starter at all. At that point the starter has already done its job & turned off.
Of course, I can't hear it from here, so that's why I have to ask the silly questions to clarify exactly what it's doing.
beagle76
Oct 9, 2011 12:37 PM
04accordhfp
Oct 30, 2010 08:17 PM
mrfatride
Sep 9, 2006 05:40 PM
saturdayman
Sep 7, 2006 12:18 AM
hecmang007
Nov 21, 2005 04:19 PM
