2004 Honda Accord door lock issues
Old Dec 21, 2018 | 04:43 PM
Celicool's Avatar
Please disregard. I just remember the OP can open the driver door
Old Dec 23, 2018 | 08:01 AM
Weathered's Avatar
Originally Posted by PAhonda
Try spraying some WD-40 into the mechanical lock where you insert the key by the driver's door handle. See if that frees up the key when you turn.
If the FOB is locking/unlocking other doors, that is not the problem.
Do you have the same locking/unlocking problems when you are able to turn the key in the driver's door? How about with the interior lock/unlock button?
The fob unit does not unlock or lock any of the doors. When I hit the unlock button on the fob, the lights on the car flash so it seems to be getting communication. When I hit the lock and unlock button on the door, the 3 other doors will lock and unlock, just not the driver side door.
Old Dec 24, 2018 | 11:18 AM
Weathered's Avatar
Well part of the trouble was the battery need replaced in the fob. Lights still flashed but not strong enough to unlock any doors. With a new battery, the fob will unlock and lock the 3 other doors, just not the driver side door.
Old Dec 26, 2018 | 10:24 PM
Does the mechanical post lock/unlock the driver's door?
The problem can be the lock actuator, wiring, or the driver's side door switch. My shop manual is on my home computer, so I don't have access.
The way to test is to remove the driver's door panel and unplug the actuator connector. You can connect a test light across the connector and try locking/unlocking the door. If the light flashes when you try locking/unlocking, then the actuator should be replaced.
Old Dec 27, 2018 | 03:23 PM
The Toecutter's Avatar
My thought is it's an electro mechanical problem,or an actuator (might be kaput) in other words, or the wiring to it... broken wire or no power to the actuator.
Old Dec 29, 2018 | 11:57 PM
vitalnet's Avatar
If you have to wiggle the key to unlock the door, I would lubricate with some wd40 first, before doing any other testing, since it is a good idea anyway, and so easy.
frankenstein69
Dec 28, 2014 12:36 AM
csh217
Jun 17, 2014 05:53 PM
H0nda04
Apr 11, 2013 06:59 PM
Doublel
Mar 11, 2013 07:57 AM
THEBIGZ
May 17, 2012 04:30 PM
