2004 transmission problems dead
Old Dec 1, 2014 | 08:44 AM
ken59's Avatar
Default 2004 transmission problems dead
Daughter's Honda broke down on Wednesday night. Tranny problems, won't go into gear fwd or rvs. There is fluid. Ay thoughts on these tranny's, costs, repair shops in northern Virginia? Help needed or I'm stuck driving daughter around for ever. Thanks
Old Dec 1, 2014 | 04:42 PM
woody31's Avatar
Almost A Senior Member
Default repair shop options
Hi , I recently had my transmission rebuilt by Mr. transmission in tyler tx,,Google
Mr.transmission virginia and this came up,,several locations ,,good luck
newportnews.mrtransmission [DOT] com
Last edited by shipo; Dec 1, 2014 at 04:53 PM. Reason: Remove URL for non sponsoring company.
Old Dec 2, 2014 | 05:30 AM
Turtlehead's Avatar
It depends on whether it is a 4 or a 6 cylinder. Given the lack of information the one thing that I would be checking is that gear selector button on the shifter is properly engaging. They sometimes get dirty and stick. Also, it is rare that a honda won't go into either forward or reverse so I am wondering if there is a problem with he shift linkage(s). Be sure that the fluid level is at max. If the fluid level is too low the torque converter won't engage thus not allowing the transmission to go into gear.
The cost will vary depending on if it is the transmission or something else noted above. Please provide information on the type of engine and I will check with a mechanic I know in Richmond, VA and see if he knows of any good shops in northern VA.
Old Dec 2, 2014 | 08:36 AM
ken59's Avatar
Thanks for replies. I'm gonna have to get it towed to specialist today. I fear its blown, but will get honest assessment. V6, auto, fluid good, no noises, just no go. I was reading about these trans and the torque converters going bad. If I find out what when wrong, I'll post. Thx
Old Dec 2, 2014 | 10:40 AM
Turtlehead's Avatar
Good luck! My bud in Richmond said to check out Toyota and Honda specialist in Alexandria.
Old Dec 2, 2014 | 07:31 PM
When you say it will not go into gear, do you mean the shift lever is stuck in P, or will the car not move when you get the shift lever in D4?
Old Dec 3, 2014 | 08:49 AM
ken59's Avatar
Report is torque converter let go and ruined the trans. So complete rebuild on its way. All over but the crying now.
Lenno
Jan 29, 2012 07:45 PM
hk15
Jul 5, 2011 06:38 PM
ohill1981
Jun 16, 2011 11:48 PM
KimberlyC
Apr 16, 2006 11:51 AM
2pwrful
Mar 14, 2005 04:22 PM
