2005 honda accord 6 cylinder, 3,0 ex manual hard shift and grind
Old Dec 4, 2023 | 05:04 AM
Screedop's Avatar
Default 2005 honda accord 6 cylinder, 3,0 ex manual hard shift and grind
I just bought the car at auction drove it home and transmission real hard to get 1st grinds into 3rd. Can't get reverse. Changed transmission fluid with honda fluid didn't change a hole lot. No visible leaks in Master or slave. I need help fixing the problem
Old Dec 4, 2023 | 11:35 AM
Scan for codes to see if the PCM detected something. When you changed the transmission fluid, did the old fluid have a bunch of metal shavings in it? How much fluid did you drain/add to the transmission?
Old Dec 4, 2023 | 02:47 PM
Screedop's Avatar
Default Trans oil
Oil was dark no shavings in it. Drained out 2.25 quarts put 2.25 back in. Haven't scanned cods yet
put in reverse withengine off it starts with clutch in. No jerking. Clutch pushed in running grinds trying third and 4th little grind in 5th goes into 6th can't get reversereal hard force to get 1st
Old Dec 4, 2023 | 03:54 PM
I just realized that you have a manual transmission on this. Codes won't apply to internal transmission issues.
I guess try bleeding the clutch hydraulics and make sure the slave cylinder is extending the piston when you push in the clutch pedal. If that doesn't help, then you probably have to tear apart the transmission to fix.
Old Dec 4, 2023 | 05:11 PM
Screedop's Avatar
Default Application
Thank you very much for your help
cukaracha
Jul 19, 2015 01:28 PM
coolaccord
Jul 15, 2014 01:07 PM
tpishori
Oct 28, 2012 09:36 AM
Primebeatz
Feb 10, 2012 08:48 PM
maq1982
Dec 19, 2008 02:14 AM
