cant shift
Old Feb 7, 2012 | 08:27 PM
Primebeatz's Avatar
Default cant shift
I have a 2002 EX coupe with manual transmission. 160k miles. Suddenly my clutch was really soft and would press all the way down easily. I could drive and shift normally with no noise or anything. No leaks, all fluids good. Some days clutch would feel normal. Other days it was super soft. About two weeks after that started, I cranked the engine (always kept in neutral while parked) and i was unable to go into 1st gear or any gear while car was on. I could start car in any gear. I could start car in 1st and drive around, but unable to shift to the higher gear while engine was running. Any ideas what the problem could be?
Old Feb 7, 2012 | 10:33 PM
Does it feel like you are trying to shift without pushing in the clutch pedal?
It sounds like you have a problem with the clutch master or slave cylinder. Check that you have fluid in the clutch master cylinder reservoir. If you are going to replace them, I would replace them as a pair.
There is a good video on YouTube by ericthecarguy on how to change the master and slave cylinder.
Old Feb 8, 2012 | 12:34 AM
UhOh's Avatar
Originally Posted by PAhonda
It sounds like you have a problem with the clutch master or slave cylinder. ...
Yep, agree from your description
Old Feb 8, 2012 | 07:14 AM
I guess I'd try bleeding the clutch fluid first. Loss of fluid and/or air in the lines also fits the problem.
Look for clutch-fluid leaks, you WILL have to find & fix the leak. One possible leak location is alongside the clutch master piston rod. It leaks through the firewall & soaks into the padding beneath the carpet and you don't notice it leaking.
Old Feb 8, 2012 | 08:49 AM
Primebeatz's Avatar
I appreciate the feedback. I will look into that. Hopefully I dont run into the transmission problems that I've read are very common on my Accord. I will check out that video. Wish me luck!
Old Feb 8, 2012 | 12:00 PM
The common transmission problems you read about are automatic transmissions. The manuals are pretty bulletproof. More fun, too.
Old Feb 10, 2012 | 08:48 PM
UhOh's Avatar
after you fix the clutch, remember to replace the manual tranny fluid if you haven't already.
change specs are frequently every 30,000. easy enough to forget (experience talking).
rydnlow1120
11
Nov 11, 2015 05:29 PM
moon-doggy
Jun 27, 2013 12:53 PM
malachi_mez
Sep 15, 2010 07:59 PM
k24vtec
Jan 18, 2009 11:40 PM
MrGmo
May 30, 2008 10:18 AM
