2006 Accord EX V6 HVAC Issues
Old Sep 25, 2016 | 02:50 PM
Elder82's Avatar
Default 2006 Accord EX V6 HVAC Issues
Hello All,
I've recently encountered an issue with my 2006 Accord EX V6 coupe (Auto Climate Control) where the HVAC is either all the way at Lo or at Hi. For example, if you set the unit at 72 and you had it at lo, then the HVAC temperature out of the vents will remain at Lo. I checked the blend doors and noticed they only shift at lo or hi. I ran some tests and found that the output on pin 1 at the motor (hi driver) is .5v until 83F, then it goes to a full 12v, I would assume this should work like a rheostat and not just be on or off.
Anyone experience similar issues?
Thanks,
Tom
Old Sep 26, 2016 | 05:49 PM
You can run a test on the HVAC system and it will give you any fault codes if they are found. I would start with that test and see what code(s) it gives you.
Old Sep 26, 2016 | 08:20 PM
Elder82's Avatar
I ran the HVAC test and no codes were generated.
Thanks,
Tom
Old Sep 27, 2016 | 12:35 PM
Dr. Drivability's Avatar
Sticking temp blend door/actuator
Old Sep 27, 2016 | 05:41 PM
I think the air mix motor like a stepper motor or a power window motor. 6 volts to the motor would not keep it half open. The mix motor will get power or ground signal to move the blend door, then stop when the control tells it to stop.
If you car has temperature settings for the driver's and passenger's side of the car, see if the problem happens on both sides of the car.
kellymarie0518
Sep 11, 2014 06:12 PM
LoPan12
Feb 22, 2013 05:59 PM
jtimc7
Sep 2, 2007 08:17 AM
jasonsjwou
Sep 11, 2006 07:33 PM
