2006 Accord Power outlets
Old Jun 21, 2011 | 01:39 PM
gog222's Avatar
Default 2006 Accord Power outlets
Hell everyone,
I am new to this forum. have looked here in the past for answers to my accord problems. This is my first post , hope someone can help. On my 2006 Accord, none of my power outlets work. everything else works. All of the fuses are ok as well. Could this be a relay problem? if so, which one is the accessory outlet relay?
thanks in advance,
gary
Old Jun 21, 2011 | 01:56 PM
It could be a relay.
This is based on my 05 TSX manual (which should be very similar to your accord).
The relay is in the fuse box under the hood. If there is an identical relay, switch them to see if the power sockets work and the other component doesn't work. If you can not find another relay, or your power sockets do not work, then you can try some tests with a volt meter on the relay socket and/or the relay.
There seems to be two fuses in the under hood fuse box that could cause the accessory power sockets not to work. Just wanted to mention this incase you only looked in the fuse box under the driver's side of the dash.
Old Jun 21, 2011 | 02:18 PM
gog222's Avatar
thanks,
do you happen to know which relay it is? i see there are a few different ones.
Old Jun 21, 2011 | 03:30 PM
I made a mistake, the relay is in the fuse box under the dash. The cover should have the relays labeled on it. The owner's manual may have them labeled as well.
Old Jun 21, 2011 | 04:16 PM
gog222's Avatar
my under dash fuse panel is only fuses..no relays. I have relays in the under hood fuse box. the relays are only marked with symbols.. not sure what symbol is for acc sockets. i appreciate all your help on this, PA..
gary
Old Jun 21, 2011 | 05:25 PM
I looked at the 06 owner's manual, and the fuse layout is the same as my TSX.
Are the relays above the 33 fuses in the fuse box inside of the car?
Old Jun 21, 2011 | 07:29 PM
gog222's Avatar
no, Only 3 rows of fuses inside. i have a bunch of relays in the underhood fuse box. Only these are labeled with symbols ??
Old Jun 21, 2011 | 08:30 PM
I would probably buy the 03-07 shop manual. I got one for my 05 TSX Ebay from the seller called automanualsource for $22. I could download it almost immediately after I paid. If you plan to do you own work, this is essential, and will pay for itself when you repair one item on your car.
reddy86
Feb 10, 2012 10:30 AM
philipghu
Dec 30, 2011 08:59 PM
akennedy89
Mar 5, 2010 06:55 PM
WHATABURGER
Aug 28, 2008 02:32 PM
c33pays
Apr 24, 2007 11:24 PM
