2006 Honda Accord DRL Relay module
Old Apr 6, 2016 | 04:40 PM
asugrads's Avatar
Default 2006 Honda Accord DRL Relay module
The DRL warning light is on in my 2006 Honda Accord. The daytime running lights nor the high beams are working. Both headlight bulb filaments are intact. I've checked fuse #'s 3 and 5 in the interior fuse box. They are fine. This started when I took my car in for an oil change and as soon as I started it up, after the oil change, the DRL warning light was on and I had no DRL or high beams. I'm thinking I need to change the relay module? Help! I'm not exactly sure where it's located and I'm not sure what part number I need. Any other help advice on how I can remedy this problem?
Old Apr 6, 2016 | 07:35 PM
The fuses to check are the no. 3 and 5 fuse in the under-hood fuse box, not the interior fuse box.
The relays are part of the relay control module, which is built into the under-hood fuse/relay box. But, don't just replace a part without testing.
slippynuxx
Aug 17, 2023 02:44 PM
gtrichter
Apr 8, 2013 09:11 PM
Maxbaby
Jul 23, 2012 08:50 PM
Karmica
Nov 26, 2011 11:02 AM
nioleb
Mar 18, 2011 06:00 PM
