2007 Accord 2.4L oil leak at axle seal
Old Jun 30, 2014 | 10:26 PM
moey's Avatar
Default 2007 Accord 2.4L oil leak at axle seal
I have a transmission fluid leak at the axle seal ( where the axle attaches to the transmission ) on the passenger side. Is there a way to check that its nothing more then the axle seal itself and not something more serious like the carrier bearings? Would you feel slop? The car drives/shifts fine.
2007 2.4L Auto 102K miles
Old Jul 1, 2014 | 02:21 PM
moey's Avatar
I went back under to see if I could feel any slop in the axle I could not. Hopefully I would feel something if the transmission were bad internally.
Any recommendations for seal brands or should I just stick with a OEM one? Closest dealer is unfortunately about 45 minutes away.
Old Jul 1, 2014 | 03:38 PM
For oil seals, I recommend OEM. Usually better fitment and less chance of it leaking shortly after the installation which can happen with some aftermarket seals.
Old Jul 2, 2014 | 08:54 AM
Roader's Avatar
From my experience searching for used 5th Gen transmissions, you can feel the slop yanking the axle up and down and the seals won't leak unless there's quite a bit of slop. The seal will seal even with ~ 1/16th inch movement.
X2 on OEM seals. Mail order is an option.
fusionstar
Sep 18, 2013 06:42 AM
Erah562
Dec 6, 2010 02:12 PM
RA1525
Mar 18, 2010 02:13 AM
nixalot
Jan 25, 2007 02:02 PM
