Cam Seal? Engine Oil Leak!
Old Dec 5, 2010 | 11:48 PM
Erah562's Avatar
Exclamation Cam Seal? Engine Oil Leak!
I have a 1996 Honda Accord ex. 4 cydin. v tech i have a bad oil leak on my passenger side. when i start my engine all my oil comes out My guess it is the cam seal. How do i replace the cam seal or also how do i know if its bad?
please help. thanks
Old Dec 6, 2010 | 12:02 AM
Probably the balancer shaft seal. Years ago, Honda sent out letters to have a retainer installed and replaced the seal as necessary. It usually is the only seal that will cause the big sudden leak on the 5th gen and some 6th gen Accord 4 cylinders.
tegger.com/hondafaq/tsb/accord/x00-073e.pdf
Old Dec 6, 2010 | 12:06 AM
Erah562's Avatar
Okay thanks
but do you know how to check the cam seal?
Old Dec 6, 2010 | 12:12 AM
Refer to the technical service bulletin (tsb) above. I didn't add the "www" as live links are not allowed on this forum. Refer to the bulletin, and you should be able to readily see the area where the leak is coming from.
Old Dec 6, 2010 | 12:17 AM
Oh snaps. I just re-read your original post. It said a bad leak from the passenger side. Hmmm...
I am so use to the major leak from the balancer shaft seal.
Old Dec 6, 2010 | 12:22 AM
deserthonda's Avatar
if it leaks on pass side , it is NOT,,,,,,,,, neither the cam nor the balancer shaft seal.......
is leak coming from top?? if so, could be valve cover gasket,, distr o-ring, v-tec solenoid seal
if from below, could be,, pan gasket, rear main seal,,
Old Dec 6, 2010 | 09:13 AM
Passenger side in USA? Passenger side in UK? Erah doesn't say where he is located.
Cam seal would leak roughly below the external drive belts (alternator, AC, PS).
Old Dec 6, 2010 | 02:12 PM
Ahhhhh.. did not think about UK car...if so.......a leak that big would have to be the balancer shaft seal popped out
phantom699
Apr 2, 2013 07:09 AM
honDUHchick
Mar 8, 2013 06:53 PM
Sethgreen
Aug 4, 2011 01:58 PM
