2007 accord power windows
Old Jun 22, 2009 | 06:04 AM
dgp1961's Avatar
Almost A Senior Member
Originally Posted by Daver
same problem on my 2007
Yesterday they worked fine on my ride home. got in this morning only drivers side works. I hear the regulators click in each of the other doors. if I engage the switch to disable them I do not hear the click.. damn dealer wont see me until monday at the earliest any ideas?
Dave, Monday's past did you ever get to the dealer? What did they say it was?
Old Jun 23, 2009 | 10:02 PM
mntentman
Exact same problem in my 05. Only driver's door window worked yesterday, then all were fine this morning, but tonight same issue is back. It has been hotter than blazes here, I can't imagine how that might impact it, but is it possible? (Car was hot yesterday then cool this morning, hot again this afternoon.)
Old Jun 24, 2009 | 07:04 AM
Bad connections in the multi-switch pack (driver's door handle) affected by heat?? Especially connections at the little switch that disables all the other windows...
Old Aug 3, 2009 | 05:38 PM
dsgb's Avatar
Did anyone find a solution to this problem yet? I'm having the same problem.
Old Aug 4, 2009 | 06:35 AM
Welcome dsgb! What car? I've fixed a similar problem (not a Honda) by dismantling the switch pack & cleaning up a bunch of old dried-up grease in the contacts.
Old Aug 4, 2009 | 08:31 PM
dsgb's Avatar
06 honda accord
Old Aug 4, 2009 | 08:48 PM
  #17
I don't have a wiring diagram for your accord, so I won't be able to give you specific information.
Remove the door panel for the window that is not working then plug back in the electrical components.
There should be be two pins at the connector for the window motor. One should get 12V when you attempt to open/close the window. The other pin should be grounded. Use a volt meter to identify what is missing at the motor. The ground and 12V wire will differ depending on whether you are trying to open or close the window.
Further diagnostics would be based off of what you find.
Old Aug 5, 2009 | 06:40 AM
  #18
I think in 2006 there's also multiplexers that have something to do with controlling windows & locks.
Old Sep 4, 2009 | 09:35 AM
  #19
drugrep's Avatar
Default Same problem with Windows here on my 2007 Accord
Greetings all, I just joined the forum for this exact problem. I searched posts and come up with this thread.
I too have a 2007 Accord EX-L, 4 Cyl. 4-Door
My driver window works fine.
All 3 Passenger Windows won't roll down.
I do hear a clicking in each window when I attempt.
If I push the window lock button and try clicking goes away as should be expected.
Any thoughts appeciated.
Old Sep 4, 2009 | 10:40 AM
  #20
Is the clicking loud or soft?
What I'm getting at, if it's loud maybe the window motor is trying to operate but the window glass is stuck.
If it's soft, then maybe the limit switch (pinch-protection) that's supposed to stop the window, is shutting off the window incorrectly.
I'm mostly trying to get information for other guys to help. I've never had to dismantle the window motors in MY Accords.
