2007 Accord Shift Lever Panel Light Not working
Old Nov 9, 2010 | 09:46 PM
clim53's Avatar
Default 2007 Accord Shift Lever Panel Light Not working
The light for automatic shift lever (between the front seats) is not lit. Is there a buld that illuminates the shift lever panel, could it be a blown fuse, or is there a dial/dimmer that controls the shift lever light? If there is a bulb, how do I (step by step) remove the panel and get to the bulb to replace it? 2007 Accord 2.4L EX VTE
Old Nov 9, 2010 | 10:09 PM
If you had a blown fuse, other electrical parts would be messed up. I would suspect a bad bulb or loose bulb.
A Haynes manual would be a good investment to help you out.
Here is Youtube video to take out the cover around the shifter at the beginning and the change holder: youtube.com/watch?v=1y9ESsUzqfo
Then I think you have to remove the cup holder. There will be screws under there. There is also a trap door at the bottom of the storage pocket under the arm rest. There are also some screws at minute 1:35 that you can see under where the change holder was.
baffled
Feb 13, 2013 07:26 AM
panoman
Dec 7, 2012 06:45 PM
wifes01
Aug 17, 2011 04:16 PM
19962door
Nov 12, 2009 09:27 PM
foxylady23
May 14, 2008 12:50 AM
