Hard to press transmission shift lever button
Old Dec 5, 2012 | 07:07 AM
panoman's Avatar
Default Hard to press transmission shift lever button
2001 Accord LX The button on shift lever is hard to depress -- first press in the morning is 'easy' but then becomes resistant and depresses slowly with steady resistant pressure. No problem actually shifting just hard to press the button in.
Old Dec 5, 2012 | 11:49 AM
I would suspect the lock-out feature is partially engaging causing the button force to be high. Only way to know is pull the console off and inspect.
Old Dec 5, 2012 | 12:11 PM
Silver6gen's Avatar
Agreed^
did something get spilled in there?
Old Dec 5, 2012 | 10:48 PM
panoman's Avatar
Nothing spilled -- it feels 'hydraulic' -- like pressing a plunger on a syringe with syrup in it.
Old Dec 6, 2012 | 02:45 PM
You might have luck taking the top handle off & try to lubricate the parts?
Attached Thumbnails Hard to press transmission shift lever button-2001-shift-selecter.jpg
Old Dec 6, 2012 | 07:37 PM
panoman's Avatar
Solved! Took the top handle off and lubricated the parts --- works perfectly! Thanks!
Old Dec 7, 2012 | 06:45 PM
Thanks for coming back with the answer
revbjeff
Apr 4, 2013 12:12 PM
baffled
Feb 13, 2013 07:26 AM
wifes01
Aug 17, 2011 04:16 PM
19962door
Nov 12, 2009 09:27 PM
foxylady23
May 14, 2008 12:50 AM
