2007 Accord V6 AC Compressor/Metal Particles
Old Mar 24, 2021 | 08:23 PM
saveabuckchuck's Avatar
Default 2007 Accord V6 AC Compressor/Metal Particles
I'm going to be replacing my AC compressor soon. I've read a lot about checking for metal particles and having to flush the AC system if metal particles are found. My question is how do I know if the old compressor put metal particles into the system? Are the particles easy to see? Where should I look to find them? Appreciate any input. Thanks everyone.
Old Mar 24, 2021 | 09:23 PM
Why are you replacing the a/c compressor?
When my a/c compressor stopped working, I had the R-134a removed by a shop. I took off the hoses to the compressor and poured some denatured ethanol down the hose and drained the hose on to a white paper towel. The grey metal shavings were obvious.
I replaced all parts that were within my budget (condenser, compressor, hoses). I found an evaporator that was from a wrecked vehicle that had no shaving from my ethanol test, and used it as that part was expensive. All new o-rings. Its been about 7 years since the repair and the a/c is going strong on my TSX.
To save money, you can keep flushing the components with water until you are confident that the metal is gone. Drain as much water as possible, then flush with the denatured ethanol to help dry out the components.
At minimum, the receiver/dryer will need replacing if you have metal in the system.
saveabuckchuck
Aug 30, 2020 08:51 PM
Ezequiel Morales
Jul 14, 2020 06:06 PM
bjr001
Jun 29, 2016 03:59 PM
thetowerxxx
Jul 10, 2014 10:58 AM
abelh7
Jul 7, 2006 08:02 PM
