2007 Honda Accord VP - Rear Brakelights/Taillights not working with Headlights on
Old Jun 7, 2021 | 09:39 PM
spgview's Avatar
Default 2007 Honda Accord VP - Rear Brakelights/Taillights not working with Headlights on
Got a 2007 Honda Accord VP has the rear led taillights and new 7443 Bulbs left and right (single filament)
Issue: With headlights/combination switch on I have no rear brake LED running lights. If I press the brake the LED on left and right maker lights illuminate (work) and along with the center brake light. However, all rear light are off with headlight switch on(no brake pedal pressed).
All fuses are good. I looked at the Circuit diagram for a 2007 Honda Accord (non hybrid) figure 23 and it appears there is a “taillight relay”. I don’t think the brake pedal position switch is bad, as it works when pressing the brake pedal.
I ordered a combination switch/headlight switch to replace but am leaning towards it being a “taillight relay”
I cannot seem to locate the “taillight relay” or where it’s located. According to the lighting circuit diagram figure 12 it indicates (No.4 15amp) “relay control module” on the “control block”
does anyone have pictures , or experience a similar issue, seems to be under the hood, might be an oversight on finding it. All help appreciated
Old Jun 8, 2021 | 12:59 AM
The brake lights circuit is separate from the taillight circuit.
For the taillights not working, did you check under-hood Fuse No. 4 (15A)?
Old Jun 8, 2021 | 08:30 AM
spgview's Avatar
Thanks! Turns out I blew the fuse #4 as you mentioned, oversight on my behalf. Thanks again!
Honda2000
Feb 21, 2021 05:18 PM
kazeuchia
Oct 23, 2017 12:02 PM
misterdeez
Jul 27, 2013 09:38 AM
LisaG
Apr 17, 2013 09:04 AM
Prizma
Jan 4, 2012 07:30 PM
