2007 Remote trunk release problem
Old Apr 19, 2016 | 09:27 AM
dwbaalmann's Avatar
Default 2007 Remote trunk release problem
Hi All,
I have a 2007 Accord SE V6. Recently a problem began where the trunk will not unlatch from the key fob. I can hear the solenoid activate when I press the button, but the trunk does not open. The manual release from inside the car works fine.
Any idea what the problem may be? Is this something a reasonably handy person can attempt (not a mechanic by any means) or should I just take it to the repair shop?
Thanks.
Old Apr 19, 2016 | 10:25 AM
rockhoundrob's Avatar
Open the trunk and close the latch itself (don't close the trunk). just use a screwdriver to close the metal "hook" that moves when you close the trunk.
Push the button and see if the latch releases. If not, then check the solenoid. Just because it is clicking doesn't mean it works. There can be a click, but the actuator does not move. It should be easy to replace.
civilfox
Oct 15, 2023 01:49 PM
ghostpilot
Jul 9, 2011 01:12 AM
b4l
Jul 10, 2010 04:15 PM
Green_Accord
Apr 25, 2007 10:39 PM
kennilope
Feb 22, 2007 03:34 PM
