2008-2012 2.4 Accord P0339, Long Cranking, Starters, Etc.
Old Sep 9, 2024 | 06:02 PM
Teacher Gear's Avatar
So, they called and said it must be the starter...they said it looks like an aftermarket starter. BUT, I bought a MITSUBA starter 2 yrs ago and had it installed...isn't MITSUBA an OEM part????/ I was told it was when I bought it.
Old Oct 30, 2024 | 01:27 PM
MammothHog's Avatar
Does anyone have new information in regards to this thread. I’m having similar issues. I replaced my starter 6 months ago. A few months after that I started having intermittent issues with difficulty starting and limp mode. The code was this infamous p0339. I bought an “oem” crank position sensor from eBay, replaced it, and then the car wouldn’t start at all. Assuming it was a fake and needed relearned anyway I had a legitimate $158 cp sensor put in by mechanic and relearned. 1 week later same issue and same code. The mechanic isn’t sure what to do. The starter put on came from oreillys so he might change that to an oem. He mentioned getting the car to Honda for a software update. This is getting expensive and we are just guessing. Any new mode of thought on this.
Old Oct 30, 2024 | 01:45 PM
Mine had the software update at the Honda Dealership.....still same problem. Honda couldn't figure it out so i SOLD IT for 1400.00 and found a deal on a great car that actually STARTS EVERY TIME!!!
Old Oct 30, 2024 | 02:11 PM
MammothHog's Avatar
I’m starting to think that’s what I’m going to have to do
Old Nov 17, 2024 | 07:41 PM
Klafae144's Avatar
Default I’m probably late hope you got it fixed.
Did you ever get the Cylinder Misfire checked out? You probably need new a ignition coil and spark plug. Anytime my 08 Accord started Jerking and barely wanted to crank it was because of the Misfire. i’m sure P0339 was an issue for you as well but maybe take a look at the spark plug and coils as well.
mdharris11
Feb 7, 2022 03:59 AM
NinjaChachi
Jun 17, 2019 05:17 PM
indy_accord
May 9, 2012 10:26 AM
jastunna1987
Dec 22, 2007 04:15 PM
drfrankencopter
Oct 28, 2007 08:36 PM
