2008 accord 4 cyl in limp mode multiple times??
Old Feb 20, 2017 | 08:21 PM
mhope1's Avatar
Question 2008 accord 4 cyl in limp mode multiple times??
I have an 08 accord 4 cyl. went into limp mode this is the 4th time. I had it re-flashed each time (local garage). Parts replaced are crank position sensor twice, cam position sensor, serpentine belt, spark plugs, battery, oil/filter and air filter. It will run ok for a couple days then all starts over again also has VSA light. This may not be related but sometimes the radio will go off and my daughter will pull over and turn the car off then back on and the radio will work again?? Please help!:
Old Feb 20, 2017 | 08:44 PM
Get the trouble code(s) read and post them.
Why were the crank position sensor and cam position sensor replaced? Was it due to trouble code P0341? If so, the issue is probably due to a stretch/damaged timing chain and not the sensors. Low oil levels or infrequent oil changes are usually the cause of a stretched chain.
Old Feb 20, 2017 | 09:13 PM
mhope1's Avatar
had a code for crank position sensor of i think it was p0339? i changed that part was from autozone, then the local garage said it needs changed maybe the one i put in was bad, he put in one from honda. cam sensor had oil leak around it per local garage. I asked the mechanic at the garage kinda of what your talking about I believe. I asked if the the chain/belt could be lose/stretched or maybe a tension pulley weak/worn giving it slack? He didn't feel like that was likely.
Old Feb 20, 2017 | 11:46 PM
Ask the local shop what version of the PCM software they flashed on your PCM. Also ask if they did the crankshaft pattern clear and learn procedure on the new sensor.
Old May 13, 2022 | 04:24 PM
Rvillalobos1's Avatar
2008 Honda accord was the issue resolved please help im having the same problem with my car i have replaced everything don't know what to do
Old May 13, 2022 | 07:52 PM
This is a 5 year old thread, so maybe the original poster will respond with their fix.
In your case, start a new post, so this thread doesn't get confusing.
Post what parts you replaced. Also post the trouble code(s) you have, so we can provide some guidance.
Even if mhope1 responds, your root cause may be different.
imsohungover
Mar 29, 2025 02:27 PM
Idle4evR
Jan 14, 2012 05:33 PM
sitedude
Oct 22, 2011 02:07 PM
thumper44
Sep 22, 2010 05:02 PM
ronjr8102
Aug 31, 2010 07:05 PM
