2009 Accord 3.0 timing belt tensioner install
Old Feb 26, 2018 | 01:20 PM
malread's Avatar
Angry 2009 Accord 3.0 timing belt tensioner install
new to forum. need help with timing belt tensioner installation directions. In particular how to release the pulley tensioner to allow enough room to install the hydraulic tensioner. thanks
Old Feb 26, 2018 | 06:27 PM
Not sure if I'm following correctly....if you have a new tensioner, it should be "pinned", if you are reusing the old one, you will have to compress it and then "pin it" before trying to install it.
Old Feb 26, 2018 | 06:41 PM
Are you reusing your tensioner?
Old Feb 26, 2018 | 07:13 PM
malread's Avatar
No not using old tensioner actuator and no I have not pulled the pin on the new one. I probably did not explain well. So here goes..... when the old tensioner actuator was removed the belt pulley that has the mating leg that the actuator pin contacts has now rotated downward in the direction of the actuator. So once I insert the new actuator into its location and attempt to line up the bolt holes to install that part the belt pulley is in the way and obviously spring loaded. I am trying to determine how to rotate the pulley enough to get the actuator bolted into place and release the pulley against the pin. does this make sense?
Thanks
Old Feb 26, 2018 | 07:36 PM
You should be able to push the tensioner pulley/arm up with your hand and install the hydraulic tensioner with the pin installed. Once the belt is properly lined-up, then you can release the pin to set the tension.
Old Feb 26, 2018 | 07:42 PM
These are timing belt removal, installation and replacement instructions.
Attached Thumbnails 2009 Accord 3.0 timing belt tensioner install-timing-belt-removal-1.jpg   2009 Accord 3.0 timing belt tensioner install-timing-belt-removal-2.jpg   2009 Accord 3.0 timing belt tensioner install-timing-belt-removal-3.jpg   2009 Accord 3.0 timing belt tensioner install-timing-belt-removal-4.jpg   2009 Accord 3.0 timing belt tensioner install-timing-belt-removal-6.jpg
2009 Accord 3.0 timing belt tensioner install-timing-belt-removal-7.jpg   2009 Accord 3.0 timing belt tensioner install-timing-belt-removal-8.jpg   2009 Accord 3.0 timing belt tensioner install-timing-belt-removal-9.jpg   2009 Accord 3.0 timing belt tensioner install-timing-belt-removal-10.jpg   2009 Accord 3.0 timing belt tensioner install-timing-belt-removal-11.jpg
...Continued.
Attached Thumbnails 2009 Accord 3.0 timing belt tensioner install-timing-belt-removal-12.jpg   2009 Accord 3.0 timing belt tensioner install-timing-belt-removal-13.jpg
Old Feb 26, 2018 | 07:43 PM
malread's Avatar
ok but what's the trick? it feels spring loaded and wont move without a pry bar? do I need to loosen anything? obviously I'm doing something wrong or missing something. frustrating the ##*#*#* out of me right now.
Old Feb 26, 2018 | 07:49 PM
malread's Avatar
ok so if I understand correctly you cannot simply remove the old and install the new?!! Timing alignment will be screwed up correct?
Old Feb 26, 2018 | 08:03 PM
malread's Avatar
still don't understand why there is tension on the pulley? no way its moving by hand
