2009 Accord 3.0 timing belt tensioner install
Old Feb 26, 2018 | 08:06 PM
malread's Avatar
I noticed my title shows a 3.0 its a3.5 but I'm sure you all knew that. my apologies, fat fingers
Old Feb 26, 2018 | 08:20 PM
Are you replacing just the tensioner, or are you doing a complete timing belt replacement on your car?
Old Feb 26, 2018 | 08:23 PM
malread's Avatar
all I was trying to replace was the hydraulic tension actuator not timing belt.
Old Feb 26, 2018 | 08:33 PM
malread's Avatar
all I have done is remove the old hydraulic tension actuator. the new one will not fit because of the pulley that the pin from the actuator engages has rotated into the way
Old Feb 26, 2018 | 09:09 PM
That pulley should swing without issue. It isn't spring loaded.
You asked a question about installing a new hydraulic tensioner and screwing up the timing. The important part for timing is keeping the belt in place from the lower crank sprocket, to the front cam, and to the rear cam. The side of the tensioner just pushes the belt in to remove all slack and keep it tight.
When I've done a timing belt with 2 cam sprockets, I used a binder clip on each cam sprocket to hold it in place. I used white out to mark a toot of the metal crank sprocket and marked the side of the 2 teeth on the belt on each side of that metal tooth. Make sense?
If you keep the belt in place at those 3 points, you won't mess up the timing.
Watch the video on a V6 accord timing belt. That pulley with the metal arm should swing without issue. You may have to slightly loosen the bolt where the pulley swings to break it free. #7 in the picture below. Then tighten #7 back down.
Louay
Jan 30, 2012 11:15 PM
thesameguy
Nov 13, 2009 05:09 PM
freezerman
Apr 17, 2009 03:55 PM
94Honda
Dec 12, 2007 07:08 PM
