2009 Radiator Fan doesn't come on
My car will overheat at low speeds unless I have the AC on.
I have replaced the coolant temperature sensor and all relays without success.
This leads me to believe it is a wiring issue but I cannot find good info on how to diagnose and replace. I feel confident I could replace the connector to the ETC but without help I can't imagine replacing the wire past a few inches without help.
Any recommendations / help would be greatly appreciated!
Do you have a V6 or 4-cylinder engine?
When the engine is cold, remove the radiator cap and check that the coolant is filled to the top. Add coolant to the radiator if needed to fill to the top.
When the temperature rises on the thermostat at idle, let us know which fan(s) are turning on without the a/c turned on.
Should be on the driver's side of the radiator on the bottom. Part number should be 37870-RTA-005. Go to a site like hondapartsnow.com and enter your vehicle info in. The part is under electrical/exhaust/... section then radiator. That wiring is exposed to the bottom of the car, so take a look at the wiring/connector to that sensor and look for obvious damage or corrosion in the connector before just replacing the sensor.
Carrameow
Jan 30, 2014 05:35 AM
scansbar
May 18, 2009 03:24 AM
