2013 lx speaker upgrade problem
Old Nov 20, 2012 | 06:21 PM
fatboy's Avatar
Default 2013 lx speaker upgrade problem
Hi, maybe someone can answer this question, I went to an after market place to upgrade my 2013 lx 4 door with aplpine 610c's in the front and 610's in the back plus an amp. They cannot figure out how to disconnect the anc without disabling Bluetooth, I guess both systems share mics and after the intial installation there was big time humming and feedback so they are opting to disable the ANC Would happen to know where i could find a wiring scmatic or possible answer Thanks
Old Nov 20, 2012 | 07:00 PM
As a temporary solution to turn off ANC (Active Noise Cancellation) while retaining HandsFreeLink (HFL), try this:
1. Push buttons 1, 6, and the power button at the same time to go into diagnostic mode.
2. Push button 1 to turn off ANC.
However, ANC will automatically turn back on though the next time you start your car.
Most likely, the permanent solution would be to disconnect the wiring for ANC mic. input. I do not have the wiring diagrams for the 2013 models.
Old Nov 20, 2012 | 07:58 PM
This was the solution in the previous generation Accord.
How to retain HFL while disabling ANC - Drive Accord Honda Forums
I do not currently have the 2013 wiring diagrams to compare to the previous generation circuits.
Old Dec 22, 2012 | 12:14 PM
Here is the solution to disable ANC (Active Noise Cancellation) while retaining HandsFreeLink (HFL) for the 2013 Accords. Refer to Post #35.
ANC Mic Location? - Page 3 - Drive Accord Honda Forums
humblehyper
Jun 30, 2014 07:51 PM
David Medina
Mar 6, 2014 07:47 PM
garyrocky1
Feb 15, 2014 10:11 PM
diyorpay
Jan 28, 2011 11:55 PM
spt118
Jan 24, 2006 10:47 PM
