2014 Accord EX-L warning lights go on and off. FCW, LDW, steering, antilock, brake.
Old Jun 20, 2023 | 09:48 AM
14 Accord EX-l's Avatar
Default 2014 Accord EX-L warning lights go on and off. FCW, LDW, steering, antilock, brake.
I have 2014 EX-L chasing this problem for a while and frustrated. Warning lights intermittent. Steering, FCW, LDW antilock and brake. Did hard reboot problem still present. Lights would be off and idling on driveway and lights go on. Car still runs fine and when I run system check everything passes. Any clues.
Old Jun 21, 2023 | 03:35 PM
You may want to check you battery voltage across the battery posts when the engine is off and turn on the headlights to remove the surface charge. Also test the battery voltage when the engine is running.
Old Jun 23, 2023 | 10:34 AM
Default Checked voltage on 2014 Accord EX-L
Need an exorcist to remove ghost from the car.
Battery voltage after cleaning posts
car off at battery posts. 12.43 volts
car on at battery pots. 14.22 volts
voltage at alternator 14.27 volts
when terminals disconnect headlights on and jumper wire between terminals to bleed of any residual voltage. Lights were off and idling lights came back on while in the driveway idling.
Very frustrating
elephants21@yahoo.com
May 5, 2023 06:17 AM
jkm831
May 2, 2023 07:14 PM
sparkiee
Nov 6, 2018 06:16 PM
denmick
Nov 1, 2014 01:17 PM
brettdog
Jan 24, 2014 01:54 PM
