2015 accord dash lights
Since the check engine light is on, you can stop by a parts store and see what code(s) are stored. The other lights look like traction control/abs. Not sure why the maintenance wrench light is on. They could all be related to one issue. Post the actual code on here. They start with the letter P and have four numbers, like P1234.
Just went through this with my 2017. Diagnostics pointed to the LR speed sensor. Turned out one of the wires corroded and failed right at the harness connector to the sensor. Dealer techs did not find this. They replaced the sensor and the problem persisted. I lifted the car and inspected the connection myself and found the problem. They repaired the harness connector as I couldn’t do that myself due to the break being right at the connector. Two hours and $431 later I got my car back. Had to pay $45 for a sensor I didn’t need.
At $155 an hour for labor, I recommend exhausting all DIY options first.
marky4
Sep 5, 2006 03:21 AM
