2016 accord tire pressure,abs,traction control,power steering on at same time
Old Oct 6, 2025 | 01:18 PM
dctaz37's Avatar
Default 2016 accord tire pressure,abs,traction control,power steering on at same time
We were driving along and all these warning lights came on at the same time. Where do I start troubleshooting?
Old Oct 7, 2025 | 02:29 PM
If you don't have a scanner, stop by a parts store and have the codes scanned to get a better idea of the issue(s).
Old Oct 7, 2025 | 04:17 PM
dctaz37's Avatar
I don't have a scanner and the parts stores around here don't scan. Can you recommend a scanner for this purpose?
Old Oct 8, 2025 | 07:18 PM
Most inexpensive bluetooth OBD2 scanners can read the check engine light codes using a free app like torque. Not sure about the abs and airbag codes.
Old Oct 14, 2025 | 03:24 PM
dctaz37's Avatar
I picked up a scanner Autel Autolink AL619 (
Amazon Amazon
) and it indicated that the right rear abs sensor was bad. It was seized and took a lot of effort to get out. Found a video where you heat up a screw and thread it in, cool it with water then pry on the screw. Did this twice with a hammer prying and another taping it finally came out. Video to remove broken ABS sensor[b]
#91;/b] . I bought all four replacement sensors in which the two rears are the same. Cleaned the hole many times as the new sensor was very hard to get it. It ended up breaking trying to get it in so I had to repeat the removal process. Cleaned a little more and eventually was able to install the second one I had. Now I get ABS sensor installed incorrectly error code 16-15. Any help please? Can you lube the outside of the sensor to get it in? I didn't want to wire brush/clean too much.
David Robertson
Dec 20, 2018 06:48 AM
Cj Larson
May 7, 2016 12:30 PM
ctmlaw
May 1, 2016 05:54 PM
19962door
Jul 9, 2013 05:24 PM
