Curb Hit
Old May 7, 2016 | 12:21 AM
Cj Larson's Avatar
Default Curb Hit
Alright, so tonight I was driving along the road and one way or another I ran into the curb. I hit the front right tire but it was more or less parallel with the curb. I checked for damage but the only thing seems to be a scuff on the hub cap. The tire doesn't even really have damage except for a tiny little burn line. The hub cap was slightly bent and so I just pulled on it a little and it went back to normal. Did I get lucky? Or is there something lurking under sight? The car seems to drive exactly the same.
Old May 7, 2016 | 09:33 AM
Dr. Drivability's Avatar
As long as it still drives in a straight line and there is no vibration, you'll be fine. Sometimes the tire will develop issues down the road, so keep an eye on it.
Old May 7, 2016 | 12:30 PM
The first thing I would do is put the front of your car on jack stands. Turn the steering wheel until it locks. Grab the tire at the 12&6 o'clock position and push/pull on the tire. Do the same at 3&9 o'clock. You should have very little play.
The slight movement is only from play in the steering wheel lock. You can also have an assistant hold the steering wheel, then you should have zero movement in the tire.
It is probably a good idea to at least get the alignment checked.
hcord13
Aug 11, 2013 10:48 PM
killersoundz
Dec 8, 2008 12:51 PM
19Accord97
Dec 10, 2007 10:42 PM
gliff159
May 4, 2007 09:43 AM
Clint.E
Feb 21, 2007 02:32 AM
